iieeann's avatar
iieeann
Nighthawk MR1100 M1 map USB drive?
I would like to know is there a way to map a network drive for the USB drive connected to MR1100?  I can use it normally under MyMedia, but it is troublesome to open the browser to login everytime to upload or download files.  It is simply too troublesome and not practical to use.
ReadyShare seems does not work with MR1100, and i can't use ReadyShare Connect to map the network drive. Can't use USB connection for printer as well.
There is a new M2 as the successor of M1, does M2 support ReadyShare?
Thanks.
