Nawem
May 04, 2020Aspirant
Nighthawk MR1100 mobile router SKU 6420B (unlocked) won't connect to Rogers in Canada
I used this router on AT&T in the US - works fine. Got it unlocked, and trying to connect to Rogers cell service in Canada (with Rogers sim card), and it will not connect! Anyone else done this succ...
- May 06, 2020
You need to set the APN manually for Rogers: lteinternet.apn. The device should work on Rogers.
