RedRaspberry
Mar 07, 2020Guide
Nighthawk MR1100 not shown on WiFi networks
I have an unlocked AT&T MR1100. It has a Consumer Cellular SIM and connects to a T-Mobile network. Firmware is NTG9X50C_12.05.05.12. I have it connected to a R6300 router with Ethernet. After ...
- Mar 09, 2020
If there is not WiFi client connecting to the device, WiFi will be turned of.
You can press Power button once to turn on WiFi again. Or you can log in to WebUI to set the WiFi never goes to standby to address the issue permanently.
Thanks
JohnPeng
Mar 09, 2020NETGEAR Expert
Thanks
