OkieBobby
Nov 19, 2019Guide
Nighthawk MR1100 reboots randomly
First time posting here. I have searched the forums and haven’t seen this particular issue. I have the Netgear Nighthawk MR1100/M1 for use with OTRMobile that uses ATT towers. I live in a rural are...
jlam1
Nov 22, 2019Initiate
Since the new firmware upgrade to 12.06.08 I am experiencing similar behavior. I am running without battery with the Anker plug and prior to the update it ran for weeks if not months on end. Since the update it has been rebooting every couple days. And rebooting is not really the correct term. It is just shutting down and requires the power cable to be disconnected and then reconnected. I am going to put the battery in with the old charger and see if that helps. Very annoying as I use this at a cabin an hour away which makes getting it reconnected a chore.
Sonko
Dec 28, 2019Aspirant
Same issue here. Once a day my M1 “hangs” meaning it appears to brick itself: the LCD screen will not come on despite multiple button pushes or holds, and strangely, the LED is blinking rapidly a very faint orange color. Holding the power button does nothing. Only unplugging the powered usb and reattaching seems to resolve the issue. I use my M1 without WiFi attached via Ethernet cable to a new Netgear router, Ethernet Port sleeping is disabled, as is WiFi from the M1. No battery installed either...using an Ankor 18w qualcom quick charge adapter. Yes, running current firmware too. Having this happen once a day is not convenient by any means. Suggestions?
