dosbirn
Nov 23, 2024Aspirant
Nighthawk MR1100 Replacement for AT&T ZTE Z700A Homebase?
Looking to finally upgrade my old AT&T ZTE Z700A Homebase wifi (hotspot) box. AT&T is telling me there is nothing I can use but I believe some people have used the Nighthawk MR1100. My ZTE has ...
rcpax
Nov 24, 2024Luminary
If you plan on using the same SIM on a new hotspot, why not go for a 5G one. The MR1100 is a 4G LTE hotspot and is quite outdated, unless you already have one, but if you have to purchase one, a used MR600 5G hotspot is really not that expensive. probably a little bit more than a used MR1100, but it will perform way better. ATT does provisions their SIM for 5G access, so ask them first if they are able to do that for your SIM.
dosbirn
Nov 24, 2024Aspirant
Thank you! That’s exactly what I was wondering, if there was a 5g upgrade. Last time I researched, only the MR1100 was available (as far as I could find).
I’m calling them tomorrow with these suggestions. Thanks again!
