Jabalous
Jul 20, 2019Follower
Nighthawk MR1100 Sim Card Connector Replacement
Hi Unfortnately after trying to force a sim card into the connector of MR1100, one of the pins was broken and now the device is not able to identify any sim. I do not believe there is a way to fi...
JSchnee21
Jul 21, 2019Virtuoso
Well, I admire your enthusiam. But in this day and age most electronics are treated as disposibles. Occassionally, if you can find the part, you might get lucky. But in many cases these devices aren't designed for serviceability. You might find a junk one on ebay for $50 and then canibalize the parts out of that. Or buy a whole used/refurb one for $50-100 (not a Nighthawk though).
