Sandra_l
Sep 17, 2019Aspirant
Nighthawk MR1100 SIM Card not installed
Hi, I kept getting the error message that my SIM is not installed even when it is. I have tried it in 3 different countries with 3 different sims and it’s always the same problem. The service provi...
W1lliam
Sep 17, 2019Virtuoso
Was this MR1100 locked to a certain carrier? What model is your MR1100? You can check on its label on the back, after removed the battery.
Sandra_l
Sep 24, 2019Aspirant
It wasn't locked to a specific carrier as I used it twice with 2 different carriers before it decided to pack up. It says MR1100.
Thank you.
- W1lliamSep 24, 2019Virtuoso
The SIM slot on MR1100 is microSIM, and if the SIM card you used to test were nanoSIM wit an interposer, then it is quite possible the SIM card not plugged well as the SIM slot is not designed for user to insert your SIM card easily, the contacts in SIM slot might have problem so your SIM card can't be reqcognized.
