mjohnbollinger
Sep 22, 2020Follower
Nighthawk MR1100 Something Unusual On Battery Display
The display shows NETGEAR, then the light in the top right hand corner start to blinking yellow, then blue, then yellow, then blue, then yellow then it quits. Where it first showed NETGEAR now it sh...
Blanca_O
Nov 22, 2020NETGEAR Employee Retired
Hi mjohnbollinger,
Welcome to NETGEAR Community!
Kindly do a factory reset using the Reset button. Press and hold the Reset button for five seconds. The mobile router returns to factory settings.
Please contact support to better isolate the issue for possible hardware problem.
Blanca
Community Team
