expresspotato's avatar
Mar 30, 2021
NightHawk MR1100 Strange WiFi 2.4 Ghz behaviour
Hello,
The WiFi chipset in this device should be able to fly on 2.4 Ghz, but something's off with the way it's been configured... On my MR1100 device WiFi performance on 2.4 Ghz occilates between fast and slow, as if the chip can't make up it's mind as to which rate to support or some buffer setting just isn't quite right. There are no other WiFi networks on 2.4 or 5 Ghz near me.
I've never seen any WiFi router do this. It's not the cellular network as 5 Ghz is fine and there is barely any usage up here on the tower up in Kingston, Ontario, Canada. Rock solid with my cell.
I should note this is when I'm in the other room from the router, if I'm in the same room it doesn't exhibit this behavour. Still something's off with it's firmware / configuration of the Atheros chip in it.
    • expresspotato's avatar
      expresspotato
      Wow strangely enough that was it! I've never had problems like this so it was a real shock to me... Device is in the next room, I'm here with the laptop and cell phone.
      The drop is me turning on Bluetooth on my laptop.
