molste74
Jul 22, 2020Follower
Nighthawk MR1100 suddenly started freezing internet connection and requiring reboot often
Using it with an AT&T SIM card.
Never had issues, already tried factory reset and signal refresh from SIM provider.
Always worked fine.
Problem started after a blackout (using power, no battery).
Can it be the cause of the issue?
It just freezes the internet connection (stop working) but it stays on (no standby) and gives no messages. After rebooting, it works again.
- NetseraphAspirantSame thing happened to mine.
- icarusponyLuminary
While it is happening are you able to ping out? I suspect both of you haven't fully investigated if the whole connection is down. Websites being accessible does not necessarily mean it is "frozen" or that your internet connection is completely down. Your connection consists of 65,536 ports and the web only accounts for 2 of those ports. Have you tested the other 65,534 ports? Are you able to ping sites?
- NetseraphAspirant
ping was fine. If I used VPN, I could still connect to web sites. Without VPN, http/https access was blocked. It seems to be an issue on ATT side.
icaruspony wrote:While it is happening are you able to ping out? I suspect both of you haven't fully investigated if the whole connection is down. Websites being accessible does not necessarily mean it is "frozen" or that your internet connection is completely down. Your connection consists of 65,536 ports and the web only accounts for 2 of those ports. Have you tested the other 65,534 ports? Are you able to ping sites?
