diehummel
Apr 15, 2018Aspirant
NightHawk MR1100 Telstra to Netgear Stock EU
Hello, does anyone know, if it is possible to flash an Netgear EU firmware over an Telstra Firmware? I own an telstra device and stuck at firmware 10.16.04.04. I read that there is already a new...
- Apr 24, 2018
Hi diehummel,
If you refer to the link below, It is instructions to manually update your Telstra M1 device.
Please let me know if this works for you. :]
https://kb.netgear.com/000055962/Why-can-t-I-see-data-usage-on-my-Telstra-Nighthawk-M1
- Jason N
diehummel
Apr 30, 2018Aspirant
Thanks!
But 2 days ago, i got the update also with the update button.
However, the new version works much better now :)
br
JasonN
May 01, 2018NETGEAR Employee Retired
Hi diehummel,
That's great! I'm glad that you were able to update the firmware and that it works for you! :]
Thank you for letting us know!
- Jason N
- diehummelMay 18, 2018Aspirant
Hello,
the 10.25.01.01 seems still a litte buggy.
The Ethernet Port ist set to Standby disabled, but when i restart my PC, i have to push the button the the M1 to get Ethernet working again.
The PC has a Static Private IP.
I have now changed the Standby Setting again to 2 Minutes and reverted to disabled to check if its working now.
The M1 crashed 2 days ago. Maybe he lost this setting during the crash and used the 2 Minutes as default afterwards.
br
Christian- diehummelMay 19, 2018Aspirant
i found, that the cause that the ethernet stoppped working, was, when my pc crashed.
i have an mining tool running, and the tool caused a crash of my pc. Everytime the PC crashed, the M1 stopped working on the ethernet port.
But the PC is not connected directly to the M1. Its connected to a GB Switch, then to an TP-Link Router, and then the M1.
When i shutdown/reboot the PC normal, the problem does not occur.
