Dylanmr1100
Jan 13, 2021Aspirant
NightHawk MR1100 won’t enable wifi from website
Brand new out the box there is no wifi enabled.APN also needed to be set up. I plugged wifi box with Ethernet cable into my laptop to access it through the website and I was able to set up the APN but...
Dylanmr1100
When clicking to enabled dual broad board or either 2.4 or 5g it just sits there trying to apply changes. Doesn’t do anything.
Jan 13, 2021Guru - Experienced User
you might get more help in the mobile router forum.
https://community.netgear.com/t5/Mobile-Routers-Hotspots-Modems/bd-p/aircard
if you're logged into it through the browser, what do you get when you go to settings->setup--->wireless
- Dylanmr1100Jan 13, 2021AspirantIt says wifi disabled. Then I go to the set up wifi and when I click the wifi I want to enable it doesn’t enable it. It just sits there buffering on the browser and the left hand bottom corner says applying changes but it never applies the change.
- plemansJan 13, 2021Guru - Experienced User
It shoudn't have come with wifi disabled.
Factory resetting might not be a bad idea. You can find the factory reset button under the battery cover. push and hold it for 10 seconds
- Dylanmr1100Jan 13, 2021AspirantI factory reset it like 10 times no changes. I’ve been on hold with customer service on the phone for an hour so far. No help yet :(
