Dylanmr1100
Jan 13, 2021Aspirant
NightHawk MR1100 won’t enable wifi from website
Brand new out the box there is no wifi enabled.APN also needed to be set up. I plugged wifi box with Ethernet cable into my laptop to access it through the website and I was able to set up the APN but...
Jan 13, 2021Guru - Experienced User
you might get more help in the mobile router forum.
https://community.netgear.com/t5/Mobile-Routers-Hotspots-Modems/bd-p/aircard
if you're logged into it through the browser, what do you get when you go to settings->setup--->wireless
Dylanmr1100
It says wifi disabled. Then I go to the set up wifi and when I click the wifi I want to enable it doesn’t enable it. It just sits there buffering on the browser and the left hand bottom corner says applying changes but it never applies the change.
- plemansJan 13, 2021Guru - Experienced User
It shoudn't have come with wifi disabled.
Factory resetting might not be a bad idea. You can find the factory reset button under the battery cover. push and hold it for 10 seconds
- Dylanmr1100Jan 13, 2021AspirantI factory reset it like 10 times no changes. I’ve been on hold with customer service on the phone for an hour so far. No help yet :(
Netgear support isn't always the fastest. Some times its easier/faster to just exchange it from where you bought it.
