stabo's avatar
stabo
Follower
May 26, 2021
Nighthawk MR1100
Hello all,
I added a TP-link ethernet-switch to my Nighthawk MR1100-100 and since then it seems to lose connection to the internet occasionally (every other day or so). I cannot see on the router display that it has lost connection but this must be the case. After a shut-down and restart it works again.
Since the router is used in a summer house with smart-home systems for temperature control etc, it will be annoying if the problem continues. It should be noticed that this has occurred twice during a four day period and I am not sure if it will happen again.
Any ideas how to handle the problem is highly appreciated.
Best regards,
stabo
1 Reply
  • Blanca_O's avatar
    Blanca_O
    NETGEAR Employee Retired
    Hi stabo
    Welcome to NETGEAR Community!
    Is this an unmanaged or a managed switch?
    Please check if Ethernet Standby if it set to disabled. Here's how: Access M1 Settings page > Settings > Setup > Mobile Router Setup > Ethernet Standby (disabled or 2 minutes) > Apply
    Blanca
    Community Team
