TheStranger
Jul 05, 2021Follower
Nighthawk MR1100
My Nighthawk suddenly went stone cold dead overnight. I read this had happened to someone on another closed thread but the remedies were not included. Does anyone know how I can get my router serviced...
Razor512
Jul 05, 2021Prodigy
Are you able to remove the back panel (it should slide off), and then use a toothpick or paperclip to press the reset button for around 15-20 seconds?
