cjoliver
Jan 07, 2022Aspirant
Nighthawk MR1100
I accidentally blocked all my devices from the users list while in the app. I can't figure out how to get back into it and allow my devices. Help?
JohnPeng
Jan 07, 2022NETGEAR Expert
Please do a factory reset and start over again.
Thanks
cjoliver
I just figured that out, thanks.
I can't remember what to put in when it asks for ATN info. Can you help me with that?
- JohnPengJan 07, 2022NETGEAR Expert
You can log in to WebUI using the info printed on the product label under the battery.
Please advise your carrier and SKU of your M1. Usually, APN can be populated automatically based on the SIM card inserted.
Thanks
- cjoliverJan 07, 2022Aspirant
ATT
MR1100-100NAS
It's saying my cellular data is not on. I go to settings/network and it appaers it is on.?
cjoliver wrote:
ATT
MR1100-100NAS
For AT&T, you need to set APN as broadband if it is not set and used a default. Make sure check the radio button in front of the AT&T APN to make it default.
You can send me a modem.json file to check by email following the steps below. My email address is jopeng@netgear.com
- Logon to the webui (http://192.168.1.1 ) as an administrator
- Navigate to URL http://192.168.1.1/model.json via the same browser window
- Capture the results (by selecting all + copy) and send it back
