AnFear
Sep 09, 2022Follower
Nighthawk MR1100
How do I disable data roaming my router will not recognise user name and password as supplied please help
Blanca_O
Sep 12, 2022NETGEAR Employee Retired
Hi AnFear,
If it is not accepting the admin password then you may need to factory reset the unit.
You may also want to check ths following link:
AirCard Mobile Hotspot and Mobile Router Login Information
To turn off and on roaming [page 33 - 34]
https://www.downloads.netgear.com/files/GDC/MR1100/MR1100_UM_EN.pdf
Blanca
Community Team
