StefD74FR
Nov 23, 2020Aspirant
Nighthawk MR2100 - random reboot
Hi I have purchased a Nighthawk MR2100 4G router 6 months ago and I am now experiencing random restarts from the M2 - I get disconnected and when I look at the LCD screen the modem has re-initial...
Nazareth
Dec 27, 2020Aspirant
facing the same issue after the update.. please kindly post back if incase you had solved the problem... thank you
