musashi84
Jan 27, 2022Aspirant
Nighthawk mr2100 - stuck on factory reset
Hi, I did start a factory reset as which the device stuck at rebooting. Only 2 out of 4 dots and it red flash's for the next eternity. During the process no interaction or interruption on my sid...
snoozername
May 09, 2022Aspirant
Same thing exactly happened to me. Did you ever find a way to restore it?
- musashi84May 10, 2022Aspirant
Unfortunatly not!
Despite the similar or identical problems some customers have, authorities aren't any helpful as "try booting without sim".
You can boot your device in a "flash mode" on which it awaits a firmware. As long as a drive and firmware to flash is missing, no progress I guess.
