c-m-
Jul 02, 2021Aspirant
Nighthawk MR2100 / M2 - 0 days remaining
I've factory reset numerous times, re-configured the data usage numerous times & tried two different network sims in the router that I've just bought and every time the days remaining value will not ...
c-m-
Jul 08, 2021Aspirant
I’ve done that and there is no difference.
On my wifi, that the router is offloaded to it doesn’t make any difference, it just hangs.
Is there another way to update it?
Thanks
Thanks
c-m-
Jul 09, 2021Aspirant
Right, I tried via Ethernet this time - the UX of the device & app are quite poor. After faffing around changing the subnet I see the time now displays, so access to the NTP is there.
I can’t upload a photo from my phone, as the forum won’t allow it, but it says
Last checked 9/7/21
Firmware version
NTGX24_10.17.08.00
Current software up to date
I’m
On smarty (three) in the U.K.
The 0 days issue is still there..
Last checked 9/7/21
Firmware version
NTGX24_10.17.08.00
I’m
- c-m-Jul 09, 2021AspirantOh and pressing
Check for update, using the app or web interface just hangs - it doesn’t ever timeout.
