Shogun8000's avatar
Shogun8000
Nighthawk mr2100-100eus
Firmware ntgx24_10.17.08.00 cannot get this to update time so will not update firmware. on three network in uk. resets not working for me. tethering on WiFi still not updating. contacted support...
  • Shogun8000's avatar
    Jul 16, 2022
    After loads of changing settings I found a solution that worked for me.
    logged into home Wi-Fi.
    switched on dmz and it updated time and said software upto date.
    switched off dmz when finished(this setting was in web settings)
    hope it helps someone.
