tickertapes
May 24, 2021Aspirant
Nighthawk MR2100 firmware checking and wont update
Does anyone know if theres a way to check for a firmware update? I'm currently using an O2 sim but have tried EE and Vodafone but dont seem to be able to contact Netgear's servers.
michaelkenward
May 25, 2021Guru - Experienced User
Visit the support pages:
Support | NETGEAR
Feed in your model number and check the documentation for your hardware.
Check the section in the manual Update the Mobile Router Firmware.
You may have done that already. I can't tell from your message.
I mention it because Netgear gave up on supplying paper manuals years ago and people sometimes miss the downloads.
Not sure what this means:
tickertapes wrote:
.....dont seem to be able to contact Netgear's servers.
What are you doing and what happens?
