Charlie2022
Mar 17, 2022Aspirant
Nighthawk MR2100 keeps ‘freezing’ - wifi connection drops out / cannot turn on the screen
I have had this mobile router since December, and having constant problems with it. Firstly we notice that the wifi signal has dropped down to almost zero (I am able to check this via my provider ap...
JohnPeng
Mar 19, 2022NETGEAR Expert
Please make sure you upgrade to the latest release.
FW: NTGX24_10.19.03.00_00
PRI: 05.02
Thanks
ulfertg
May 30, 2022Initiate
JohnPeng
My device doesn’t find a new firmware through the update check of the up or the web interface.
It claims that the current FW is the latest.
Details of the device below.
How can I update the firmware?
Nighthawk M2
Hardware Version
1.0
GUI Version
MR2100-100EUS 04.02.171.00
Firmware Version
NTGX24 10.17.08.00
PRI Version
05.04
Modem Version
SDX24 10 25.00.06
Firmware Build Date
2020/08/21
