Justin_Smith
Apr 20, 2020Initiate
Nighthawk MR2100 M2 - Firmware no longer updating
Hi, My MR2100 last checked for a firmware update on 5/11/19 and is currently on NTGX24_10.16.03.00 When I press the "check for update" it just sits "checking" for ever and never completes. ...
- Aug 25, 2020
THX John - good hint!
I tried updating when Data Offloading was on LAN so NTP would go thru... and that worked!
THX
BJ
JohnPeng
Apr 21, 2020NETGEAR Expert
Please advise your country and carrier you are using.
Thanks
Justin_Smith
Apr 22, 2020Initiate
I am in the UK and it's an EE sim in there :)
- JohnPengApr 22, 2020NETGEAR Expert
It has been confirmed by one of EE UK customers that after he switch to another network, his device can be upgraded successfully.
We are working with EE UK to resolve the issue.
Thanks
- SluckP2May 17, 2020Aspirant
I have the same problem in germany with the provider german telekom.
If I switch to Ethernet via offloading the update is greyed out.
Using the broadband will endlessly scan for a new firmware.
Best regards,
Nils
Workaround:
The scan is working if the provider connection has been established and afterwards the offloading via Ethernet will be enabled.
Best regards,
Nils
