Justin_Smith
Apr 20, 2020Initiate
Nighthawk MR2100 M2 - Firmware no longer updating
Hi, My MR2100 last checked for a firmware update on 5/11/19 and is currently on NTGX24_10.16.03.00 When I press the "check for update" it just sits "checking" for ever and never completes. ...
- Aug 25, 2020
THX John - good hint!
I tried updating when Data Offloading was on LAN so NTP would go thru... and that worked!
THX
BJ
Retired_Member
Jul 24, 2020Hello Guys,
i have the same problem. Someone has a solution?
I come from Austria and this is my Model:
Nighthawk M2
Hardwareversion: 1.0
Firmwareversion: NTGX24_10.16.03.00
Modemversion: SDX24_10.24.00.00
GUI-Version: MR2100-100EUS_04.02.124.00
PRI-Version: 03.02
Firmware-Erstellungsdatum: 2019/08/02
Best Regards,
hellraver
- Retired_MemberJul 24, 2020Problem solved. I have reset the M2 to factory settings. Then an update was found and successfully downloaded and installed :-)
- btromsdorfJul 27, 2020Tutor
Lucky you :) Firmware reset didn't work for me.
- Retired_MemberJul 27, 2020After the firmware reset, if you checked for a new update, the router was in the original settings?
