Justin_Smith
Apr 20, 2020Initiate
Nighthawk MR2100 M2 - Firmware no longer updating
Hi, My MR2100 last checked for a firmware update on 5/11/19 and is currently on NTGX24_10.16.03.00 When I press the "check for update" it just sits "checking" for ever and never completes. ...
- Aug 25, 2020
THX John - good hint!
I tried updating when Data Offloading was on LAN so NTP would go thru... and that worked!
THX
BJ
ulfertg
Sep 11, 2020Initiate
I'm having this issue for month and just came back here to check if there is a solution available.
None of the workarounds descibed in thie thread worked for me.
I'm honestly pretty surprised that a company like Netgear seems to be having this much trouble just to get a basic function working again.
Cage1010
Sep 16, 2020Guide
Hi, I have both MR1100 and MR2100, and I noticed that my MR1100 can have better performance than MR2100.
Below link is the screen shot including MR1100 and MR2100 speedtest result and device information.
Is there any firmware update for MR2100 to catch up the performance as MR1100?
Thank you.
Best regards, Cage.
MR1100 SpeedTest and Device Info.
https://drive.google.com/file/d/1qlFCRwTz-bOmpBPY4zNNkFr-hvs1cl4u/view?usp=sharing
MR2100 SpeedTest and Device Info.
https://drive.google.com/file/d/1FIwPUjUdY1DEs_DwbQLBYYK79QKjWJbh/view?usp=sharing
