Esmaeel91
Jul 27, 2020Aspirant
NightHawk MR5100 Connection Speed
Dear All I'm Using MR5100 for my 5g connection its a really good router that can provide the speed that you expected from it. but I have 2 Issues with it :- 1- when I connect it through U...
Esmaeel91
Jul 28, 2020Aspirant
any help please ?
icaruspony
Aug 02, 2020Luminary
I can't help with this. But I remember how happy I was to get a 14.4 kbps modem upgrade from 2400 baud. Now I'm reading a post saying, "I can ONLY get 1 gigabit" and it's making me think about life.
- Esmaeel91Aug 05, 2020Aspirant
the 1 gigabit belong the the connection between router and pc
its not the speed of the internet
- icarusponyAug 05, 2020LuminaryHow are you measuring speed between the PC and hotspot via ethernet without involving USB, cellular or WiFi?
- Esmaeel91Aug 06, 2020Aspirant
There is 3 Methods to connect your router to the pc
1- Via Ethernet Cable which give me 1 Gb/s Connection
2- Wireless which give me 851 Mb/s on AC and 1.2 Gb/s on AX
3- USB Cable ( Tethering ) which give me 851 Mb/s
not i'm not talking about internet speed
i'm talking about the connection speed between the router and pc as we now the connection between them on Ethernet Cable and Wifi 1 Gb and 1.2 Gb
my question : why usb cable ( Tethering ) dont give 2.5 Gb/s like other hotspots from huawei is there a problem on my router or it just cant reach more than 851 Mbs
best regards
