Esmaeel91
Jul 27, 2020Aspirant
NightHawk MR5100 Connection Speed
Dear All I'm Using MR5100 for my 5g connection its a really good router that can provide the speed that you expected from it. but I have 2 Issues with it :- 1- when I connect it through U...
icaruspony
Aug 05, 2020Luminary
How are you measuring speed between the PC and hotspot via ethernet without involving USB, cellular or WiFi?
Esmaeel91
Aug 06, 2020Aspirant
There is 3 Methods to connect your router to the pc
1- Via Ethernet Cable which give me 1 Gb/s Connection
2- Wireless which give me 851 Mb/s on AC and 1.2 Gb/s on AX
3- USB Cable ( Tethering ) which give me 851 Mb/s
not i'm not talking about internet speed
i'm talking about the connection speed between the router and pc as we now the connection between them on Ethernet Cable and Wifi 1 Gb and 1.2 Gb
my question : why usb cable ( Tethering ) dont give 2.5 Gb/s like other hotspots from huawei is there a problem on my router or it just cant reach more than 851 Mbs
best regards
- icarusponyAug 06, 2020LuminaryAre you testing using the exact same USB cable that you had plugged into the Huawei? And the exact same port on the PC?
Not all USB C cables are USB3. Some USB C cables are USB2.
The USB cable on the A side should have 9 pins instead of the usual 4 pins. Even if it is blue, it may not have 9 pins inside.- Esmaeel91Aug 08, 2020Aspirant
Yea I tried the same usb cable and the same port that I used for Huawei and still cant get more than 851 Mb/s
