brandon19
Aug 10, 2021Aspirant
Nighthawk MR5100 Port Forwarding issues
So I had port forwarding enabled for HTTPS and has been working for 2 weeks no issues. Today the port was closed. I check the settings and the rule was still there so I simply deleted it and went to add it back but it now gives an error when you try to add any rule for forwarding. No matter what range or IP is used. I did a restore of the settings and the rule was not added back either.
