01UkAtO
Mar 02, 2022Initiate
Nighthawk MR5100 router connectivity issue.
I just replaced my old HFC connection with a 5g one. And have got The Nighthawk MR1500. I am trying to replace my old modem with it, But no mater what i do i cannot get it to work or even get detecte...
- Mar 09, 2022
Sorry for the late reply. I have been moving house. Turns out i just had to factory reset it a bunch of times. I did it when i first encountered the issue but it did not seem to do anything.
01UkAtO
Mar 09, 2022Initiate
Mar 09, 2022Guru - Experienced User
Glad you got it working!
You might mark it solved so others aren't trying to fix it and so others can know what fixed the issue for you
