houch_nighthawk's avatar
Jun 09, 2025
Nighthawk mr5100 vs Ethernet
ATT says I can connect Desktop to Nighthawk via a ethernet cable. Netgear says no. Who do I believe and why.
Here is ATT version:
How to connect your device to the internet via Ethernet.
Connect an ethernet cable from the ethernet port on your computer to the LAN port on the back of the Netgear Netgear Nighthawk 5G Mobile Hotspot Pro.
Any help from referees?
  • FURRYe38's avatar
    What happens if you connect your PC to the ethernet port of the MR router?
    • houch_nighthawk's avatar
      houch_nighthawk
      Good question at very beginning I tried that and I then had no internet connectivity nor any possible wifi connection. In summary when I connected a ethernet cable into the MR5100 I disconnected / prevented my MR5100 from being able to handle any wifi at all. It appears that any ethernet cable plugged into the MR5100 disables its wifi functionality.
  • schumaku's avatar
    schumaku
    Where does Netgear says you can't, please?
    https://www.downloads.netgear.com/files/GDC/MR5100/MR5100_MR5200_UM_EN.pdf is very clear. Some exceptions apply when Always-On WiFi is enabled, and the Ethernet port is used as an additional WAN port.
    Fun fact? Netgear has started offering the Netgear Nighthawk USB-C to Ethernet Adapter, allowing to connect an additional Ethernet device to Mobile Routers already coming with an Ethernet port (like your ATT MR5100), or for some less expensive models without an Ethernet port.
      houch_nighthawk
      Thanks, Schumaku.
      But working with Howly for many hours and same for ATT and also Linksys none have been able to establish an ethernet connection between my mr5100 and (at first my newly purchased Linksys MX5500) but then less convoluted a direct connection to my desktop (win 11) and lastly with my DV7 Pavilion Win7 laptop. Again I say ATT publishes yes a direct ethernet connection from desktop to the Mr5100 is possible. I checked my ATT hotspot plan and there is no restrictions on my separate line with hotspot. VERY frustrating. There are several setting on the mr5100 and tried them all i.e. tethering, wifi always on (off) , setting wifi off. Therefore I'm a very much doubter of any ethernet functionality within the mr5100. Thank you for your participation in my saga of the ethernet. This all started after many years using the mr5100 here at home (on our 80 acres) using WIFI. Here we don't have any landlines for internet and rely on the mr5100 for all internet. We used an older version of Linksys for our home networking and security system. So now we wanted to install the Linksys mx5503) (mx5500) and required hotspot e-cable to the internet port on the primary (mother) tower and to Mr5100. Then another e-cable  from my desktop (win11) to a ethernet port on same mother tower. We couldn't get the Linksys mother tower to successfully boot. Linksys tried many hours to no avail and decided the mr5100 wasn't working at the point of the e-cable on the mr5100.
      • plemans's avatar
        Did you ever try the MR5100 in passthrough mode? Both the linksys and the MR5100 have router modes and it puts you in a double nat.
    • rcpax's avatar
      rcpax
      Luminary
      Good info on the USB2Eth dongle. Browsing through the tech sheet, it sounds like it's only gigabit, which is plenty, but for a usb-c device, i was expecting it to be at least 2.5G. can't see pricing on it yet.
      • schumaku's avatar
        schumaku
        USB-C is a connector, with USB 4.0 standard supporting link rates of up to 20 Mb/s, 40 Mb/s, 80 MB/s. The USB2Eth dongle offered by Netgear is initially priced around 40 EUR / CHF, and it's inded a 1000 Mb/s GbE. Yes, for the similar price, 2.5 GbE and even 5 GbE variants are available in the market.
        The state-of-the-art Netgear M7 Pro does come with a built-in 2.5 GbE port, does offer up to 10Gbps USB tethrering, does support WiFi 7 including the 6 GHz band (up to 320 MHz bandwidth).
        The USB2Eth does include a PD-input port, required to operate, power, and charge.
        Well possible, the USB2Eth was specified to be workable with earlier Mobile routers, like M1, M2, M3, M5, M6 - despite of being USB 3.0/3.1) which don't have the hardware and software (bridge!) throughput capabilities of the M7 Pro.
        What exact usage you have in mind for this dongle?
  • Currently I have had no explanation as to why the situation where an ethernet cable connected into the Nighthawk MR5100 disables its wifi functionality. I only have documents that say that this is possible by AT&T. There is something I'm missing. But I can't get AT&T and Netgear to agree on any of these factors. Very frustrating!!!
