ReidJoy
Mar 09, 2022Follower
Nighthawk MR5200 - Can you disable 5GHz Band?..
Is there a way to disable one of the Wi-Fi bands on the Nighthawk M5? Specifically the 5GHz band in this case? I can find the instructions in the user guide of how to turn off the Wi-Fi altogether f...
steveXXX
Mar 12, 2022Apprentice
disable Dual-Band, enable 2.4 GHz only:
