JohnDyson
Sep 12, 2021Tutor
Nighthawk MR5200 extremely bad WiFi 6 latency
Why does the Nighthawk MR5200 have such bad Wifi 5 latency? I have M1 and M2 and both are fine, no great but fine, now that I buy M5 it's impossible to keep my streaming going on with this router. ...
michaelkenward
Sep 13, 2021Guru - Experienced User
You might get more help, and find earlier questions and answers specific to your device, in the appropriate section for your hardware. That's probably here:
Mobile Routers, Hotspots & Modems
Those things are very different from the standard Netgear routers covered in this section.
JohnDyson wrote:
Netgear what have you done?
Can you fix it!
You should know that this community is essentially a user-to-user venue with some input from a small band of Netgear techies who may be able to help you out.
Most of the answers come from fellow users who have no connection with Netgear. They just have a lot of collective experience and are familiar with the sort of problems that turn up here.
If you want "official" support then you should go through the right channels.
