ChristineT
Dec 07, 2021NETGEAR Employee Retired
Nighthawk MR5200 (M5) - We need your feedback!
Good day Nighthawk Community,
I'm reaching out to you today in hopes of soliciting your help. If anyone is experiencing any issues with the Nighthawk MR5200 (M5) Mobile Hotspot we want to hear ...
- Nov 03, 2022
Hi,
maybe it is possible to also help with the issue we experience.
We own two MR5200, let's call one "old" and the other one "new".
We use to run "old" with a Vodafone (Germany) SIM which originally came from a "Vodafone GigaCube", some kind of relabeled HUAWEI 5G Router. This setup was running fine for about 12 Month or so, but recently we started to experience interruptions of LTE connections after 12 to 24 hours. Only a reebot of "old" would help getting reconnected.
So we bought "new", used the very same SIM card with it. We experienced, that "new" wouldn't even connect to LTE nor any other band.
So we ordered a fresh SIM card and used in "new" but experienced the very same behaviour. "new" wouldn't connect to any band.
When using the fresh SIM card in "old", we were back to a connect time of about 12 to 24 hours, but then again interruptions of the connection.
JohnPengcould you take a look at the model.json stats if we upload them?
Many thanks in advance!
benyba
Dec 08, 2021Guide
Hi,
I'm still having 5G unstability issues described in this post :
To summarize, I'm not able to use 5G network since I've upgraded from 10.29.11 firmware. I'm obliged to force it to LTE as 5G connection is highly unstable. Latest FW didn't change anything for me.
Log examples separated by a few seconds :
"connectionText": "5G",
"sessDuration": 25636,
"sessStartTime": 1318381157,
"signalStrength": {
"rssi":-79,
"rscp":0,
"ecio":0,
"rsrp":-93,
"rsrq":-12,
"bars":5,
"sinr":1,
"end":""
"diagInfo": [ {
"lteAttached": true,
"nr5gAttached": true,
"endcEnabledConfig": true,
"ltesigValid":true,
"ltesigRssi":"-79 dBm",
"ltesigRsrp": "-93 dBm",
"ltesigRsrq": "-12 dB",
"ltesigSnr": "1 dB",
"nr5gsigValid": true,
"nr5gsigRsrp": "-114 dBm",
"nr5gsigRsrq": "-12 dB",
"nr5gsigSnr": "15 dB" "connectionText": "5G",
"sessDuration": 25786,
"signalStrength": {
"rssi":-79,
"rscp":0,
"ecio":0,
"rsrp":-110,
"rsrq":-12,
"bars":3,
"sinr":0,
"end":""
"diagInfo": [ {
"ltesigValid":true,
"ltesigRsrp": "-110 dBm",
"ltesigRsrq": "-13 dB",
"ltesigSnr": "0 dB",
"nr5gsigRsrp": "-32768 dBm",
"nr5gsigRsrq": "-32768 dB",
"nr5gsigSnr": "-3276 dB"
},{}],Thank you
Benoit
JohnPeng
Dec 09, 2021NETGEAR Expert
benyba wrote:
Hi,
"connectionText": "5G", "sessDuration": 25636, "sessStartTime": 1318381157, "signalStrength": { "rssi":-79, "rscp":0, "ecio":0, "rsrp":-93, "rsrq":-12, "bars":5, "sinr":1, "end":"" }, "diagInfo": [ { "lteAttached": true, "nr5gAttached": true, "endcEnabledConfig": true, "ltesigValid":true, "ltesigRssi":"-79 dBm", "ltesigRsrp": "-93 dBm", "ltesigRsrq": "-12 dB", "ltesigSnr": "1 dB", "nr5gsigValid": true, "nr5gsigRsrp": "-114 dBm", "nr5gsigRsrq": "-12 dB", "nr5gsigSnr": "15 dB""connectionText": "5G", "sessDuration": 25786, "sessStartTime": 1318381157, "signalStrength": { "rssi":-79, "rscp":0, "ecio":0, "rsrp":-110, "rsrq":-12, "bars":3, "sinr":0, "end":"" }, "diagInfo": [ { "lteAttached": true, "nr5gAttached": true, "endcEnabledConfig": true, "ltesigValid":true, "ltesigRssi":"-79 dBm", "ltesigRsrp": "-110 dBm", "ltesigRsrq": "-13 dB", "ltesigSnr": "0 dB", "nr5gsigValid": true, "nr5gsigRsrp": "-32768 dBm", "nr5gsigRsrq": "-32768 dB", "nr5gsigSnr": "-3276 dB" },{}],Thank you
Benoit
I can provide the instructions to allow you downgrading to the previous release and see whether your device can work normally as you expect. After that, we can get some logs on the latest release to check what might be wrong.
Thanks
- benybaDec 14, 2021Guide
JohnPengHi, I'm interested by these instructions for downgrade and ready to do some tests for you.
Thank you
- JohnPengDec 15, 2021NETGEAR Expert
Thank you
I have set up your device to downgrade to the previous release with FW 12.03.09.00 and PRI 03.04.
Please do a manuel FW upgrade check to downgrade you device and let me know if you have any issues.
Then you can let me know whether the issue you experinced with the latest release has gone.
Thanks
- TmacTradingLtdAug 28, 2022Apprentice
Hi John, Are you able to send me instructions on how to downgrade the firmware? I'd like to try downgrading to the latest prior firmware to when these issues started.
