ChristineT
Dec 07, 2021NETGEAR Employee Retired
Nighthawk MR5200 (M5) - We need your feedback!
Good day Nighthawk Community,
I'm reaching out to you today in hopes of soliciting your help. If anyone is experiencing any issues with the Nighthawk MR5200 (M5) Mobile Hotspot we want to hear ...
- Nov 03, 2022
Hi,
maybe it is possible to also help with the issue we experience.
We own two MR5200, let's call one "old" and the other one "new".
We use to run "old" with a Vodafone (Germany) SIM which originally came from a "Vodafone GigaCube", some kind of relabeled HUAWEI 5G Router. This setup was running fine for about 12 Month or so, but recently we started to experience interruptions of LTE connections after 12 to 24 hours. Only a reebot of "old" would help getting reconnected.
So we bought "new", used the very same SIM card with it. We experienced, that "new" wouldn't even connect to LTE nor any other band.
So we ordered a fresh SIM card and used in "new" but experienced the very same behaviour. "new" wouldn't connect to any band.
When using the fresh SIM card in "old", we were back to a connect time of about 12 to 24 hours, but then again interruptions of the connection.
JohnPengcould you take a look at the model.json stats if we upload them?
Many thanks in advance!
nasgulch
Jan 29, 2022Aspirant
I got myself a 5200 because my M2's work flawlessly for 2 years.
I am having the following issue. Which does not exist with the M2's.
Using Swisscom as a provider here in CH with a public IP adress, My router is assigned the adress 178.x.x.x as shown in the first image below. Strangely enough the unit reports a private IP which comes from nowhere as shown in second image. The M5 is on latest FW 12_0412_00.
What is worse, when using IP Passthrough, the private adress is forwarded!!!
Swisscom provided public IP
Any input is appreciated
Erik
nasgulch
Jan 31, 2022Aspirant
Solved.
Problem was on my end with the wrong APN settings
