ChristineT
Dec 07, 2021NETGEAR Employee Retired
Nighthawk MR5200 (M5) - We need your feedback!
Good day Nighthawk Community,
I'm reaching out to you today in hopes of soliciting your help. If anyone is experiencing any issues with the Nighthawk MR5200 (M5) Mobile Hotspot we want to hear ...
- Nov 03, 2022
Hi,
maybe it is possible to also help with the issue we experience.
We own two MR5200, let's call one "old" and the other one "new".
We use to run "old" with a Vodafone (Germany) SIM which originally came from a "Vodafone GigaCube", some kind of relabeled HUAWEI 5G Router. This setup was running fine for about 12 Month or so, but recently we started to experience interruptions of LTE connections after 12 to 24 hours. Only a reebot of "old" would help getting reconnected.
So we bought "new", used the very same SIM card with it. We experienced, that "new" wouldn't even connect to LTE nor any other band.
So we ordered a fresh SIM card and used in "new" but experienced the very same behaviour. "new" wouldn't connect to any band.
When using the fresh SIM card in "old", we were back to a connect time of about 12 to 24 hours, but then again interruptions of the connection.
JohnPengcould you take a look at the model.json stats if we upload them?
Many thanks in advance!
steveXXX
Feb 10, 2022Apprentice
Hello,
I have had my MR5200 for several weeks now and I LOVE it!
When it works, it works very well:
If I believe one of the apps on my phone, this is from a 100Mbps cell.
When working the status page shows:
Unfortunately anywhere from 10 minutes to several days it goes into this state, and the network no longer works:
Doing a "Reset" doesn't seem to clear it, but a complete "Shutdown" followed by a power cycle (10 seconds off) does.
tia,
Steve
steveXXX
Heres
No idea where my photos went, they were visible in my "compose" window...
Are there rules about max file sizes or extensiuon types?
Edit:
Nevermind, they showed up a little later... guess its a buffering thing...
Steve
