ChristineT
Dec 07, 2021NETGEAR Employee Retired
Nighthawk MR5200 (M5) - We need your feedback!
Good day Nighthawk Community,
I'm reaching out to you today in hopes of soliciting your help. If anyone is experiencing any issues with the Nighthawk MR5200 (M5) Mobile Hotspot we want to hear ...
- Nov 03, 2022
Hi,
maybe it is possible to also help with the issue we experience.
We own two MR5200, let's call one "old" and the other one "new".
We use to run "old" with a Vodafone (Germany) SIM which originally came from a "Vodafone GigaCube", some kind of relabeled HUAWEI 5G Router. This setup was running fine for about 12 Month or so, but recently we started to experience interruptions of LTE connections after 12 to 24 hours. Only a reebot of "old" would help getting reconnected.
So we bought "new", used the very same SIM card with it. We experienced, that "new" wouldn't even connect to LTE nor any other band.
So we ordered a fresh SIM card and used in "new" but experienced the very same behaviour. "new" wouldn't connect to any band.
When using the fresh SIM card in "old", we were back to a connect time of about 12 to 24 hours, but then again interruptions of the connection.
JohnPengcould you take a look at the model.json stats if we upload them?
Many thanks in advance!
Retired_Member
Feb 20, 2022Stevexxx
Steve, well after changing the Band Region settings to LTE and NR5G, and rebooting everything, it only lasted about 10 minutes before internet access dropped. I checked the modem, and it was connected with a strong signal. Logged into the router and the vpn was disconnected and would not reconnect. So I went back into the MR5200 and set it to LTE ALL as you originally stated.
Will monitor this and let everyone know.
Paul
Retired_Member
Mar 05, 2022I continue to have problems with dropped connections on my internet data service. I use AT&T service. Modem is set for all LTE service until they install 5G in my area.
This morning the network was again down. The modem was connected to one cell tower last night
which was LTE B12 band, and then this morning it had switched to another tower with LTE B14
band. Signal was strong as I use a poynting 2 x 2 mimo antenna. I am less than 5 miles away
from the towers in my area. Modem firmware is up to date. Router: Linksys 1900acsv2 running expressvpn on the router. It seems when AT&T switches cell towers on me, my modem will stay connected, but the vpn
drops the connection and prevents my network from re-connecting. I have to reboot both the modem
and router for the reconnection to take place.
This is unacceptable since I need communication for security systems and cameras when I am
away from this location. The settings on the router expressvpn are set to reboot at 4 am,
however without the ability to automatically set the modem to reboot, the network will never
reconnect without a modem reboot. VPN protocol are set to automatic, wired to modem, DHCP protocol. Regardless if ExpressVPN is
set to automatically reboot at 4 am, it still locks out the modem and will not reconnect to it,
until the modem is manually rebooted. Of course netgear will blame expressvpn and expressvpn
will blame netgear and everyone will blame AT&T!
- BartMelMar 06, 2022TutorTrying to use an MR5200 in a private 5G NSA NW. The device seems to attach properly, showing 5G symbol, but data throughput and latency indicate that it is only using the 4G anchor.
Anchor is on B40, 5G is n78 (3.7 to 3.8, 100 MHz).
Latest FW in use
QXDM is available to take traces if instructions can be provided.- JohnPengMar 06, 2022NETGEAR Expert
Latest FW in use
QXDM is available to take traces if instructions can be provided.QXDM will be really helpful in this case. Please capture QXDM logs with QTI default filter and start logging from device boot up until you see the the data connection is set up and %G icon is displayed.
We saw this issue when the 5G coverage poor in NSA mode. The network broadcast it is 5G enabled and the device is also attached to it showing the 5G capbility, but actaully, the 5G leg is not really active. We can check on this with the QXDM logs.
Thanks
John
- BartMelMar 06, 2022TutorAny special USB drivers needed to get QXDM logs?
I don't think it is an issue with signal strength as other devices connect just fine. Will try to get QXDM logs in the next days.
Is SA already supported? On the same band, we also have an SA NW active, with a different APN., but no luck to the MR to see this NW.
