ChristineT
Dec 07, 2021NETGEAR Employee Retired
Nighthawk MR5200 (M5) - We need your feedback!
Good day Nighthawk Community,
I'm reaching out to you today in hopes of soliciting your help. If anyone is experiencing any issues with the Nighthawk MR5200 (M5) Mobile Hotspot we want to hear ...
- Nov 03, 2022
Hi,
maybe it is possible to also help with the issue we experience.
We own two MR5200, let's call one "old" and the other one "new".
We use to run "old" with a Vodafone (Germany) SIM which originally came from a "Vodafone GigaCube", some kind of relabeled HUAWEI 5G Router. This setup was running fine for about 12 Month or so, but recently we started to experience interruptions of LTE connections after 12 to 24 hours. Only a reebot of "old" would help getting reconnected.
So we bought "new", used the very same SIM card with it. We experienced, that "new" wouldn't even connect to LTE nor any other band.
So we ordered a fresh SIM card and used in "new" but experienced the very same behaviour. "new" wouldn't connect to any band.
When using the fresh SIM card in "old", we were back to a connect time of about 12 to 24 hours, but then again interruptions of the connection.
JohnPengcould you take a look at the model.json stats if we upload them?
Many thanks in advance!
steveXXX
Apr 15, 2022Apprentice
BH_C wrote:
steveXXX wrote:Hi,
I found a new way to hang the M5. Have been using direct Ethernet to the main switch. Decided to tether a Beryl router
to the M5 USB port to get a few Ethernet ports at the hot spot station. Seemed ok until I ran speedtest.com. Total hang
of the M5, no front-panel, no pings, the app couldn't even see it. Tried several different cables, always the same.Restored to original direct Ethernet connection and no more hangs. Anyone else seeing hangs when tethered?
Did you mean you tether the M5 to the Beryl router's USB port and then run speed test from a computer connected to the Beryl router's Ethernet LAN port? This usually requires the USB host to support each brand/model of modem specifically... Looks the router mainly supports Android phones or iPhones.
Yes, indirectly thru yet another managed switch.
SO I guess it may be a case of "doctor, it hurts when ... | doctor: then don't do it"
Expected that sort of thing to be a standard. 😡
steveXXX
Apr 21, 2022Apprentice
Found that the issue with my M5 hang was that the Beryl didn't have enough amperage on the USB port to power
the M5 in tether mode. When the M5 got to cooking during a speedtest it didn't have the juice and hung.
For now using a battery solves the problem. Gonna try a different router long term.
As to the Beryl handling the M5 in tether mode, it works just fine since I loaded the GoldenOrb flavor of OpenWrt
firmware on it.
