ChristineT
Dec 07, 2021NETGEAR Employee Retired
Nighthawk MR5200 (M5) - We need your feedback!
Good day Nighthawk Community,
I'm reaching out to you today in hopes of soliciting your help. If anyone is experiencing any issues with the Nighthawk MR5200 (M5) Mobile Hotspot we want to hear ...
- Nov 03, 2022
Hi,
maybe it is possible to also help with the issue we experience.
We own two MR5200, let's call one "old" and the other one "new".
We use to run "old" with a Vodafone (Germany) SIM which originally came from a "Vodafone GigaCube", some kind of relabeled HUAWEI 5G Router. This setup was running fine for about 12 Month or so, but recently we started to experience interruptions of LTE connections after 12 to 24 hours. Only a reebot of "old" would help getting reconnected.
So we bought "new", used the very same SIM card with it. We experienced, that "new" wouldn't even connect to LTE nor any other band.
So we ordered a fresh SIM card and used in "new" but experienced the very same behaviour. "new" wouldn't connect to any band.
When using the fresh SIM card in "old", we were back to a connect time of about 12 to 24 hours, but then again interruptions of the connection.
JohnPengcould you take a look at the model.json stats if we upload them?
Many thanks in advance!
jrpalmer08
May 09, 2022Aspirant
JohnPeng I too have this issue as stated by kristopher_d . I was on hold with Netgear technical support for 1.5 hours and also with T mobile support. I was sent a BYOD sim card that can be used on an unlocked device and it was confirmed as such by t mobile customer service. This is NOT the issue. I currently have an open case with Netgear technical team as of 5/9/2022 and am awaiting resolution.
JohnPeng
May 10, 2022NETGEAR Expert
Could you please help to check your current plan code? You can find it on your T-Mo account as shown below.
