ChristineT
Dec 07, 2021NETGEAR Employee Retired
Nighthawk MR5200 (M5) - We need your feedback!
Good day Nighthawk Community,
I'm reaching out to you today in hopes of soliciting your help. If anyone is experiencing any issues with the Nighthawk MR5200 (M5) Mobile Hotspot we want to hear ...
- Nov 03, 2022
Hi,
maybe it is possible to also help with the issue we experience.
We own two MR5200, let's call one "old" and the other one "new".
We use to run "old" with a Vodafone (Germany) SIM which originally came from a "Vodafone GigaCube", some kind of relabeled HUAWEI 5G Router. This setup was running fine for about 12 Month or so, but recently we started to experience interruptions of LTE connections after 12 to 24 hours. Only a reebot of "old" would help getting reconnected.
So we bought "new", used the very same SIM card with it. We experienced, that "new" wouldn't even connect to LTE nor any other band.
So we ordered a fresh SIM card and used in "new" but experienced the very same behaviour. "new" wouldn't connect to any band.
When using the fresh SIM card in "old", we were back to a connect time of about 12 to 24 hours, but then again interruptions of the connection.
JohnPengcould you take a look at the model.json stats if we upload them?
Many thanks in advance!
JohnPeng
Jun 09, 2022NETGEAR Expert
dongtiendaihiep wrote:
hello, i purchase a MR5200 ( 100NAS version) from amazon to my country (Vietnam), the band n41 does not work, my firmware verion is: NTGX55_12.04.10.01 web app version: MR5200-100EUS_04.02.196.00 what should i do to unlock the n41 band?
and why my gui version is 100EUS?
please contact me via email anex3655@gmail.com many tks,
I can confirm that your device is North American SKU and n41 is supported. Could you please advise which carrier you are using in Vietnam with the device?
If possible, please capture a model.json file and send a private message to me to check.
- Logon to the webui (http://192.168.1.1 ) as an administrator
- Navigate to URL http://192.168.1.1/model.json via the same browser window
- Capture the results (by selecting all + copy) and send it back
Thanks
John
dongtiendaihiep
Jun 09, 2022Tutor
Please check your message, sir
Many thanks,
Many thanks,
