ChristineT
Dec 07, 2021NETGEAR Employee Retired
Nighthawk MR5200 (M5) - We need your feedback!
Good day Nighthawk Community,
I'm reaching out to you today in hopes of soliciting your help. If anyone is experiencing any issues with the Nighthawk MR5200 (M5) Mobile Hotspot we want to hear ...
- Nov 03, 2022
Hi,
maybe it is possible to also help with the issue we experience.
We own two MR5200, let's call one "old" and the other one "new".
We use to run "old" with a Vodafone (Germany) SIM which originally came from a "Vodafone GigaCube", some kind of relabeled HUAWEI 5G Router. This setup was running fine for about 12 Month or so, but recently we started to experience interruptions of LTE connections after 12 to 24 hours. Only a reebot of "old" would help getting reconnected.
So we bought "new", used the very same SIM card with it. We experienced, that "new" wouldn't even connect to LTE nor any other band.
So we ordered a fresh SIM card and used in "new" but experienced the very same behaviour. "new" wouldn't connect to any band.
When using the fresh SIM card in "old", we were back to a connect time of about 12 to 24 hours, but then again interruptions of the connection.
JohnPengcould you take a look at the model.json stats if we upload them?
Many thanks in advance!
MichaelDenmark
Aug 27, 2022Aspirant
Hi
I have issues choosing a WI-FI channel manually. My wi-fi net, where I live is, is wery busy. So in order to get at less busy frq, I manually try to choose from the options. But my MR5200 is ALWAYS randomly choose the frq for me. If I want ch40, I will NEWER get 40. But any other channel the device chooses for me.
I can be lucky, that after 5-10 reboots I finally get my prefered channel. I spoke to support. They know about this. But they are not able to fix this bug???
Kindest regards
Michael, Denmark
