ChristineT
Dec 07, 2021NETGEAR Employee Retired
Nighthawk MR5200 (M5) - We need your feedback!
Good day Nighthawk Community,
I'm reaching out to you today in hopes of soliciting your help. If anyone is experiencing any issues with the Nighthawk MR5200 (M5) Mobile Hotspot we want to hear ...
- Nov 03, 2022
Hi,
maybe it is possible to also help with the issue we experience.
We own two MR5200, let's call one "old" and the other one "new".
We use to run "old" with a Vodafone (Germany) SIM which originally came from a "Vodafone GigaCube", some kind of relabeled HUAWEI 5G Router. This setup was running fine for about 12 Month or so, but recently we started to experience interruptions of LTE connections after 12 to 24 hours. Only a reebot of "old" would help getting reconnected.
So we bought "new", used the very same SIM card with it. We experienced, that "new" wouldn't even connect to LTE nor any other band.
So we ordered a fresh SIM card and used in "new" but experienced the very same behaviour. "new" wouldn't connect to any band.
When using the fresh SIM card in "old", we were back to a connect time of about 12 to 24 hours, but then again interruptions of the connection.
JohnPengcould you take a look at the model.json stats if we upload them?
Many thanks in advance!
wirywizz
Oct 26, 2022Aspirant
Netgear MR5200 US model
Feedback
5G support - lacks 5G SA capability
5G support - Netgear provides NO information on when this will be supported
iphone 13 compatibility - Netgear app for Nighthawk router - prevents my iphone 13 from reconnecting to any home WiFi after use - have to reset network settings on the iphone every time - do you test your product?
5G support - uploading FW is a PITA. make it easier.
Recommendations
Provide a button that allow users to select 5G NSA or SA services
Fix the WiFi incompatibility issue with iphone 13 (latest FW)
