ChristineT
Dec 07, 2021NETGEAR Employee Retired
Nighthawk MR5200 (M5) - We need your feedback!
Good day Nighthawk Community,
I'm reaching out to you today in hopes of soliciting your help. If anyone is experiencing any issues with the Nighthawk MR5200 (M5) Mobile Hotspot we want to hear ...
- Nov 03, 2022
Hi,
maybe it is possible to also help with the issue we experience.
We own two MR5200, let's call one "old" and the other one "new".
We use to run "old" with a Vodafone (Germany) SIM which originally came from a "Vodafone GigaCube", some kind of relabeled HUAWEI 5G Router. This setup was running fine for about 12 Month or so, but recently we started to experience interruptions of LTE connections after 12 to 24 hours. Only a reebot of "old" would help getting reconnected.
So we bought "new", used the very same SIM card with it. We experienced, that "new" wouldn't even connect to LTE nor any other band.
So we ordered a fresh SIM card and used in "new" but experienced the very same behaviour. "new" wouldn't connect to any band.
When using the fresh SIM card in "old", we were back to a connect time of about 12 to 24 hours, but then again interruptions of the connection.
JohnPengcould you take a look at the model.json stats if we upload them?
Many thanks in advance!
Xop0
Oct 25, 2022Star
Just received MR5200 m5 after 3 weeks of waiting from amazon (at first they set the price of 500 euros, then canceled the order and had to order again). And it just freezes and reloads every 30 seconds. Do they test their "premium" routers at all?
What could be the solutions to this problem? How can I upload new firmware from a computer? Resetting to factory settings, working with and without a battery, mechanical reboot, USB connection, had no effect.
For some reason, I was sure that something would be wrong with the device, because even netgear's pre-sales support was terrible.
Xop0
Oct 26, 2022Star
Lol, there is no firmware updates in https://www.netgear.com/support/download/?model=MR5200
