mr_Hotspot_guy
Jan 17, 2024Follower
Nighthawk MR5200 (M5) EUS to COnnect to USA ATT Network
Hello, I have purchased an MR5200 (Nighthawk M5) hotspot with the EUS configuration. I want to use that device in the United States on the ATT mobile network. Unfortunately, there are not many b...
JohnPeng
Jan 17, 2024NETGEAR Expert
Unfortunately, there are not many bands. Is there any way to adjust the configuration of the MR5200 EUS to operate in the US for ATT?
Thanks!
MR5200-100EUS has different HW and band supports as MR5200-100NAS. It is not adjustable with FW release.
You have to get a ATT MR5100 or MR5200-100NAS to be used on ATT.
Thanks
dongtiendaihiep
Feb 28, 2024Tutor
Hi JohnPeng,
any lastest fw update fao mr 5200-nas?
still waiting for something new…
- JohnPengFeb 29, 2024NETGEAR Expert
dongtiendaihiep wrote:
Hi JohnPeng,
We don't have a plan to update the FW for MR5200.
- dongtiendaihiepFeb 29, 2024Tutormy fw is now12.04.10.01 and no have any update...would you please explain this post?2023-07-03 11:35 AM
FW 12.04.17.00 is already the latest release with the ethernet port stability fix. The PRI version should be 03.00.
As for the built timestamp, I will check whether it was a typo. The FW was build on March 1, 2023.
Thanks
Message 3 of 3 - dongtiendaihiepMar 01, 2024Tutor
- JohnPengMar 01, 2024NETGEAR Expert
Looks like your device is stuck on an old release. Could you please send me a model.json file to check?
- Logon to the webui (http://192.168.1.1 ) as an administrator
- Navigate to URL http://192.168.1.1/model.json via the same browser window
- Capture the results (by selecting all + copy) and send it backYou can email the file to me at [email protected] and mention your community ID.
Thanks
