mr_Hotspot_guy
Jan 17, 2024Follower
Nighthawk MR5200 (M5) EUS to COnnect to USA ATT Network
Hello, I have purchased an MR5200 (Nighthawk M5) hotspot with the EUS configuration. I want to use that device in the United States on the ATT mobile network. Unfortunately, there are not many b...
JohnPeng
Feb 29, 2024NETGEAR Expert
dongtiendaihiep wrote:
Hi JohnPeng,
any lastest fw update fao mr 5200-nas?
still waiting for something new…
We don't have a plan to update the FW for MR5200.
dongtiendaihiep
Feb 29, 2024Tutor
my fw is now12.04.10.01 and no have any update...
would you please explain this post?
2023-07-03 11:35 AM
FW 12.04.17.00 is already the latest release with the ethernet port stability fix. The PRI version should be 03.00.
As for the built timestamp, I will check whether it was a typo. The FW was build on March 1, 2023.
Thanks
Message 3 of 3
