victorlothbrook
Oct 23, 2022Follower
Nighthawk MR6150 and T-Mobile
After a day spent trying to figure out why I was getting an Error 1110 MM#6 when trying to setup my nighthawk with T-Mobile, wanted to share that the Nighthawk only works with T-Mobile's 50GB plan. It does not work with the 100GB plan. Hopefully, this will save someone time and frustration. T-Mobile should document this and Netgear should also let customers know the exact plan that will work with its devices.
- Blanca_ONETGEAR Employee Retired
Welcome to NETGEAR Community!
The MM#6 was Network reject code. It is nothing to do with MR6150.
Not all mobile data plans are compatible with unlocked mobile hotspots. Better check with a representative to confirm if plan is compatible.
For more information, please see: https://kb.netgear.com/000064847/
Blanca
Community Team - JohnPengNETGEAR Expert
Thanks for the information. We will add this to the KB article. Can you confirm the 100GB plan is from T-Mobile BYOD plan?
Based on our information, T-Mobile only provides maximum 50GB BYOD plan. We will check with T-Mo why 100GB is not available for M6 even though M6 was certified by T-Mo.
Regards
John
- GrundgeAspirantIs there anything Netgear can do to fix this? I am in the same boat. Have the 100 GB plan T-mobile plan and I get the MM#6 restriction. T-mobile only solution was to send me their hotspot device but that's not why I bought an $800 Netgear device. So I guess if I want this device to work I am only limited to 50 GB?
Grundge wrote:
Is there anything Netgear can do to fix this? I am in the same boat. Have the 100 GB plan T-mobile plan and I get the MM#6 restriction. T-mobile only solution was to send me their hotspot device but that's not why I bought an $800 Netgear device. So I guess if I want this device to work I am only limited to 50 GB?We confirmed that the 100GB data plan in question is actually a popular, special data-only plan by T-Mobile. But it has been locked to primarily their own hotspot devices and some selected devices (Inseego MiFi M2000 hotspot, Samsung Tab S7 and S7+, Apple iPad Pro 5th Gen, and iPad 11th 3rd Gen.). This data-only plan is not expected to work on Netgear’s devices.
You can refer to the link below for BYOD plans that are confirmed working with Netgear devices.
Thanks
John
