agold2009
Feb 04, 2025Aspirant
Nighthawk MR6150 in IP Passthrough with DHCP disabled not working
When I disable the DHCP and use the nighthawk in Bridge mode, my router wont get an IP. Is this normal? When DHCP is enabled and bridge mode is activated everything works but I am not able to get por...
agold2009
Yes you are right I realized earlier today that I have a non static IP CGNAT. What VPN do you recommend?
rcpax
Feb 04, 2025Luminary
I have not subscribed to any VPN that provides a static IP, so I can not really recommend one over another. But NordVPN seems to be a household name, you might want to check them out.
