Kragster
Sep 07, 2024Aspirant
NightHawk MR6450
Hi, Bought this 5G router for WIFi in a Tesla MYP23. It cannot seem to run at all without the battery, even if it is plugged into a wallsocket. Just keeps telling me to use the original power adapte...
Sep 07, 2024Guru - Experienced User
Probably a better power supply?
I've got the MR6150 and have run it with aftermarket power supplies and cables.
You also have to ensure the cable is high quality too.
Kragster
I bought a Quick Charge cigarette adapter that can deliver 5v 3A and I will test with that.
It doesn’t really change the fact that the product cannot seem to run without battery despite the fact that I am using the original adapter and cable in a 230v socket.
