nizdobs
Nov 13, 2024Aspirant
Nighthawk MR6500 - Powering without battery
I purchased a Nighthawk M6 Pro (MR6500) which is an AT&T branded M6 Pro. I put a TMobile SIM card in it and it was working just fine. The problem I have is that when I try to use the device without a...
nizdobs
Thank you for the reply. I purchased the item as a renewed item from Amazon. I suspect that whoever made the return substituted the wrong charging brick when they made their return.
Is it possible for me to purchase the correct charging brick from Netgear?
rcpax
Nov 13, 2024Luminary
That i am not so sure if netgear sells them (you might want to chat with support). You can also power this with some decent QC3.0 charging brick from a reputable brand. I have several power bricks I have tried with this model, as long as it can output 2A or more, and you are using one of those USB-C cables that came OEM with a fast charging phone, you should be okay. OEM is ideal, but I have this work with a lot of 3rd party cables and bricks. You just have to find which one works.
