hartj1
Oct 20, 2022Follower
Nighthawk MR6500 gets very hot and malfunctions
I would like to know if it's best to leave my device plugged into the AC adapter most of the time, without the battery in place while it's being used. Or is it best to charge the battery fully, then ...
Oct 20, 2022Guru - Experienced User
the recommendations I've seen on the forum for those that leave it plugged into AC power is to pull the battery.
If you're just running AC for charging it, then you can leave it in but if its mainly on AC power, pull it.
